Re: Western red cedar for stringers?
Just curious, as to your choice of wood as opposed to plywood as Bond-o suggests? I do understand the desire for rot resistance, however, Ext. Grade plywood, properly prepped and encapsulated in Resin and Glass, and then cared for and maintained in the correct fashion, will last for 30+ yrs. This should be more than adequate for your needs. It's lighter, more readily available, and has more structural integrity than lumber. If you research and study the threads here on the forum, you'll find that almost all of the restorations are using plywood for their stringers. The first link in my signature has some info that might be of interest to you.
This was taken from the Glen-L Boat Building Site, for your reading enjoyment
CEDAR, WESTERN RED
23 lbs. per cubic foot, 1.92 lbs. per board foot
Grown in the Pacific Northwest, the wood has narrow white sapwood and reddish-brown heartwood. It is rather soft and weak, shrinks very little, and the heartwood has good resistance to decay. The grain is uniform and straight although somewhat coarse and brittle. While often used for conventional planking, it is not highly recommended for this use. However, for veneers for use in cold molded hull planking, the material is excellent.
