BoatingTimbo
- Joined
- May 18, 2009
- 78
Out this weekend the wet exhaust hose off one of the elbows burst on port engine and all along the nearly 4 feet of hose was bubbled from from the heat.
The hose is different from the other 3 so not sure if it was replaced because of poor water flow on that side or is just the last to be replaced over the years. It felt soft and i debated changing it but wasn't sure what too soft was?
two questions:
1. replacing the wet exhaust hose; are they all standard hoses? my engines are '85 crusader 350's. Also should i just replace all 4 hoses?
2. I'm going to get an IR heat gun to understand temp of all four elbows. If i have poor water flow and the elbow is overheating what temp will it read? what are normal ranges?
engines are running at normal operatin temp.
Any help is greatly appreciated. Thanks in advance.
two questions:
