Found an interesting aid for sanding/wet sanding. Apologies if someone has found this one before. Necessity is the mother of invention. <br /><br />While wet sanding my hull and looking for something better than a regular sanding block (cramps my hands and can't handle odd areas, I stumbled upon an ideal item for the job. It was a common item that most with kids and/or pools likely have around. Am appropriate length of a Fun Noodle makes a great sanding block. Just wrap the paper around it and go. It contours to odd areas, yet still gives a reasonably flat surface for sanding. It is also a great fit for my hand. I sanded the entire bottom of my 15' tri-hull with no hand cramps.<br /><br />While this tip may be worth what you paid for it
, hopefully it helps someone out there
