Hi,
I posted this on another forum and thought I might put it up on this one as well.
I recently completed the sanding of my F/Glass boat hull after completely removing all the old paint with paint stripper.
Using a random orbital sander I was getting really cheesed off with the dust I was creating and having to wear a dust mask. (Because of poor eyesight I wear glasses all the time and with a dust mask on the glasses kept fogging up every time I exhaled.)
To solve the problem I decided to wet sand with my electric orbital sander! Now, I know that water and electricity don't mix well, and I wasn't silly enough to dunk my sander in a bucket of water, but I found I never had a problem by just using a garden hose to spray water on the hull and sand while the area was wet. I made sure of course that the powerlead plug was kept up off the wet ground.When the sanding pad clogged up it was just a matter of ripping it off and hosing the gunk off it. I was able to do the entire bottom of my boat with no dust problem and therefore no dust mask.
Am I alone in using this sanding method or is it in common use by others?
bluey.
bluey.
