I am in the process of resotring an old Ski Supreme and have a question about the exhaust. On my model the exhaust runs under the deck (outboard of the stringers). I am in process of replacing the deck and stringers so when the exhaust goes back in I want it to be 100%. I'd hate to have to cut the floor up in the future due to problems.
I plan to replace the rubber exhaust hose and double clamp all connections. My question relates to one of the tips. It appears that heat got to it at one point and it has melted - forming a bit of a cone. I cut off about 1/2" of the tip to get rid of the worst of the melted plastic. The problem is that the conical shape of what is left does not work well for clamping the hose securely. Can i build up the ouside of the tip with epoxy mat and resin to make it straight again and maybe form a lip to prevent it from sliding off? I have attached a couple of pictures of what I am dealing with. I am trying to keep cost low on this project and am surprised by the cost of these pieces if I need to replace them. All suggestions appreciated!!!
