buckeye_paul
- Joined
- Sep 6, 2010
- 21
I bought a 15ft fiberglass V hull with a 85 hp outboard in mid august and only got it in the water once so far. (Other things going on) The boat seemed in great shape. I read a thread about someone doing a restoration and he had complained about the former owner of his boat not sealing holes in the transom properly. I decided to check the transom of my boat. I took the screws out that held the speed probe, transducer, and trim tabs. There were also additional holes which looked like they had been filled with a cheap grade clear epoxy. Well all of the newer holes had no sealant or epoxy added to the holes for waterproofing and if I stick a nail in some of the holes I can wick brown water out.(not a lot) Like I said, I've only had it in the water once and that was a month ago! I know this is a serious problem. The entire transom seems very hard and stable but for how long? If I put everything back together sealing the screws and filling holes with marine epoxy, I think that will just seal the moisture in and maybe make things worse. Any opinions? I wanted to go fishing this weekend but don't want to compound the problem. Any help would be greatly appreciated. Thanks
