wet vs dry 4.3 I/O winterizing
Greetings all, after reading the exhaustive posts on the wet vs dry winerizing, I just have a couple of questions. I recently wet winterized my regal with a kit and 2 gallons of low tox from the previous owner (and his help). When I tested the antifreeze now in the boat, it was protected only to 10 above which in Ohio the temp gets to zero easily. Was I reading that most are completely draining the water and not adding antifreeze to the thermo housing as the manual suggests? Also, someone mentioned that Don S. had a post from a Mercruiser service bulletin and I was not able to find that through a search. Any help at all would be appreciated.
