WH carburetors, will these work?
GT1000000
Hello again,
I am in the process of rebuilding/refreshing/replacing the carburetors mentioned in the following posts...
http://forums.iboats.com/mercury-mariner-outboards/mercury-v-6-carburetor-jets-643331.html
http://forums.iboats.com/electrical...ken-cape-craft-bringing-back-life-633094.html
I have found some likely candidates on Evilbay to scavenge for parts or to actually replace the originals with, but need to know if the WH-3- carburetors will directly interchange with the WH-18- carbs, I have on hand?
The reason I would like to get some replacement/used carbs is that after adding up all the small parts I would need to restore the originals to working order, I would end up spending more than if I just purchase the other set and either use them as is, after a thorough inspection that is, or get the parts I need from them...
Thanks for any input!
GT1M:)
Faztbullet
Re: WH carburetors, will these work?
Wh3's will work on your engine as long as jets are correct....
