What is you replaced the manifold and block plugs on a V6 MerCruiser with small diameter (3/32") brass hose barbs. Then you route hoses from the barbs to other barbs installed in the Y exhaust pipe. While running, the motor would leak some water from the block and the manifolds, but it would not be enough to change proper operation of the mannys or the thermostat. After shutdown, the block and mannys would auto drain.
We would still need something to prevent them from clogging from rust, maybe some kind of cone-shaped screen in the block and mannys.
Do you think it would work?
