What are all of these parts for in the Thermostat Kit?
anon1
Hello,
Looking at the Mercury Marine Thermostat Kit 807252T 4 and comparing it with other diagrams I can't tell where everything goes.
The attached picture below has the parts labeled 1 through 6. Looking at the diagrams it appears that they would be installed, from the top:
- Steel Lifting Hook
- Steel Cover
- Gasket #1 (although I think that my existing t-stat has #4 here)
- Steel Sleeve
- T-Stat #2
- O-Ring #3
- Steel Housing
- Gasket #5 (I think my existing t-stat has more of a #4 here)
Which way does the t-stat get installed? Spring down or up?
Does gasket #5 go on between the manifold and t-stat housing?
Do gaskets #4 and #6 get used?
1989 Mercruiser 350magAlpha1
Thanks.
anon1
Re: What are all of these parts for in the Thermostat Kit?
Yes sir, it says right above the picture, Mercruiser 350magAlpha1.
Thank you.
Bt Doctur
Depends on how may hoses you have on the housing,this is for 6 hoses
1 gasket
spacer collar
2 thermostat ,spring facing down
3 "O" ring
5 between housing and intake manifold
can you post a pic of your housing
anon1
Thanks Doc,
I do have the 6-hose housing. I've now removed it and have the new t-stat into it and here are a couple of pictures. I'm surprised at how well the housing looks for being off a 20yr old engine.
By the way, one sensor for temp gauge, what is the other one for?
Happy Holidays.
Bt Doctur
The sensor is most likely for the hi-temp alarm system, also ones for no-oil, and low- drive oil
