Hi all, I am searching for info on a Sunbird 16, with a Evinrude 60(1996). I had a warning light peep and I am trying to get to the bottom of what it is indicating. <br />I have 4 warning lights. Overheat, No oil, Check engine and Low oil.<br />During the last two trips the low oil alarm tripped after idle then running up to cruise for about 60 seconds. <br />I immediatly shut down and inspected the power head. Nothing obvious was out of place, no plugs undone etc. I know the oil mix was correct as I do this myself.<br />After the single warning, there were no further alarms. Cautious testing did not reproduce the problem. <br />No futher alarms were tripped during the rest of the trip. I tried different speeds, quick power on and off.<br />Two questions:<br />What is being indicated and what may be the cause.<br />Also, is it safe to continue to use and observe?
