Re: What Battery size do I need for a 15HP Evinrude?
The type of battery AGM, dry-cell, wet-cell, etc. doesn't matter. The AGM's nice because you can mount it in any way shape or form you fancy without having to worry about leaking. As for the size, your 15hp motor is smaller in hp and lower in compression than most motorcycle engines so I would assume that you should be able to use a garden tractor or motorcycle battery for starting, they'd be the smallest and lightest.
