Re: What brand and weight oil / lube to use in engine & outdrive on 93 SS 4.3 OMC Cob
Grayt, I was recommended to use GL-5 Royal Purple grease in the outdrive; I believe that GL-5 is a 75W-90; but others can probably correct me if i am wrong. However, I do believe with good certainty that in any good GL-5 fluid is sufficient for the Cobra outdrive, and Royal Purple makes some pretty good stuff. Go to any autoparts store for the fluid, I usually get my Royal Purple at O'Reilly's. Make damn sure you get 64oz in the outdrive, or else you will find yourself with destroyed upper gears. Have you ever changed your outdrive lube before? If not, find a video on youtube that demonstrates on an Alpha 1. If I can do it, its not too hard! If you need any help send me a message.
For the engine, I think a lot of guys online will tell you to run Rotella SAE30, or another high ash content oil. I tend to like cleaner oils, so I run Castrol SAE30. I'm sure Rotella is great also, or a lot of guys like Valvoline SAE30. If anyone disagrees, don't be afraid to step on my toes, I'm just a Castrol guy!
