Re: What can dissolve foam?
Laddies,<br /><br />Gas You say. Hm... my gas tank is placed in foam. Should not be a good combination if You get a gas leak...<br />I will try gas and see what happen.<br /><br />Realgun,<br />The foam is around the gas tank and I want to remove the tank to be able to build a new mounting for the tank so it can be removed any time I want and to be able to inspect the tank every time before I go out to sea.<br />The tank came loose last summer and I do not want that to happen again.<br />I have a plan how to fasted it much better then the foam thing (that the boat factory used to save money).
