What caused failure?
Hooli
Ok, I have my '93 Johnson 40 torn down and ready for the machine shop. While they are doing that, I still have to determine what happened. The motor had been sitting for about a year and a half. I cleared the fuel lines and carb bowls, and drained the gas tank. Fresh fuel, and ran it. #2 scored on me after about 8 miles of driving. Cylinder and crank were DRY. I pulled the carb apart looking for an obvious obstruction and found none. Now I am nervous. If I can't find the problem I am not real comfortable running it again. Also, can I replace the rod bearings without the main bearings? Being #2 went dry, the lube on the rod bearing wasn't there either, I feel like I ought to replace them but a whole bearing kit is more than I want to do. Thanks.
tashasdaddy
Re: What caused failure?
clogged jets in the lower carb. did not deliver fuel/oil.
CharlieB
What does the crank look like?
Are you replacing the rod?
Hooli
Both rods and crank looks and feels fine, real smooth. No, I see no reason to replace the rod. So rod bearings ok?
wilde1j
Make certain you're sure of the failure cause, or it certainly will happen again.
SKEETR
Clean the rod bearings well and inspect the rollers with a magnifying glass look for pits or cracks. Chuck em if they look blue at all. Same with piston neddles. I would at least buy new pistons and wrist pins as well as rings of course.
