rolmops
- Joined
- Feb 24, 2002
- 5,594
The other day on the lake going at wot suddenly went down from 4500 to 2900 rpm.When I came home I took off the flywheel, checked the coils and points.Everything seemed to be fine.I checked for spark and the spark on both cylinders will easily jump half an inch.I checked the fuel lines and connectors for obstruction and found neither dirt nor leak.The only thing thing different was that I changed from regular tc-w3 to synthetic tc-w3.Both mixed at 1:32.Could this be the issue or is it time to clean the carb or maybe even check the reeds?<br />Just yesterday I tried to start it again and I ended up starting it with the ropestarter after having drained the battery trying to start it.<br />Thanks in advance for your opinions and help.
