Re: what causes a boat to porpoise
A "hook" is generally created from the boat sitting on malfitted trailer for long periods of time or can be placed there purposely by hull design. A "hook" will cause the bow to "plow" if it is bad enough. A "rocker" will bring the bow up. If these are not part of the hull design, your boat will always run errant unless the hull is reconstructed. Oftentimes the boat value precludeds that type of effort and expense.
(1) Properly redistribute your weight
(2) Proper mount your motor referencing you AV with the running surface of your hull. begin with flush.
(3) Trim and mark your zero trim angle for running reference. Best "at speed" efficiency is at zero or +
(4) Verify that your motor is turning at or very near the max rpms with the load that you carry trimmed at zero +. If it does not, you are propped incorrectly.
(5) The correct prop in most all, but rare instances will correct running posture, however, is the least understood by boaters.
(6) Avoid the use of "add on" regalia which can give the false impression of correction.
