Hi I was wondering what are the possible causes an engine could miss at high speed?
T Tyty Cadet Joined May 14, 2010 Messages 25 Jun 8, 2010 #1 Hi I was wondering what are the possible causes an engine could miss at high speed?
O oldgradywhite Petty Officer 1st Class Joined Sep 7, 2007 Messages 232 Jun 8, 2010 #2 Re: What causes a engine to miss bad coil, stator, trigger, switchbox, some what clogged carb jet. Most likey a switchbox though.
T Tyty Cadet Joined May 14, 2010 Messages 25 Jun 9, 2010 #3 Re: What causes a engine to miss Thank you for the help my engine is old and dosent have a switch box so I will try cleaning the jets next.
Silvertip Supreme Mariner Joined Sep 22, 2003 Messages 28,771 Jun 9, 2010 #4 Re: What causes a engine to miss If your engine is old it still has an ignition system. Engines miss because the spark or fuel is interrupted.
