What causes fuel to go back into tank after primin
tony08
What causes fuel to go back into tank after priming. Have changed backflow 3 times and bubble twice.
cyclops222
Should be bad check valves in the squeeze Primer Bulb.
Unscrew the fuel tank filler cap to release any excess ...VACUUM....in the tank.
Need a OB guy, don't know if tank has a check antisiphon valve of some sort
cyclops222
Would leaving the cap loose relieve the problem ?
A few million defective parts ?
The primer bulb is a simple manual pump.----Once it is used to fill the carburetor it does nothing !----Going soft after filling carburetors means nothing.
dingbat
You need an opening to atmosphere (leak) to break the vacuum of a sealed fuel line to allow the fuel to drain back.
A sticking float valve would do it, as would a leaky fuel fitting. Fuel filters and band style hose clamps are another common source of vacuum leaks.
FWIW: a vacuum leak doesn’t necessarily leak fuel
cyclops222
Good primer bulbs ... ONLY... pump gasoline in 1 direction. The built in check valve must prevent drain back. How else will the pump ...HOLD ...2 to 5 pounds of pressure in the carburetor FLOAT needle valve system.
My primer bulb has ROCK HARD shape a couple of days later. I DO NOT need to squeeze it at all.
Yes there really can be 3 million REJECT squeeze primer bulbs out there.
cyclops222
Think about a Primer bulb FUNCTION.
EACH squeeze is...SUPPOSED.... to INCREASE the fuel pressure in a carburetor float level that is several feet HIGHER. Than the gas level in a near empty gas tank on the floor under it. A soft bulb just does NOTHING to fill the carburetor to operating pressure.
3 million rejects and counting.
cyclops222
This spring I finally changed the primer bulb for the generator. It was just to hard to squeeze efficiently. about 35 years old. Still pumped . But caused cramped muscles in my hand.
The bulb fills the carburetor float bowl to the correct level.-----The fuel in the float bowl is exposed to atmospheric pressure.-----Once carburetor float bowls are full the bulb does nothing.
cyclops222
Some times I disconnect the hose connector at the engine and allow the carburator & pump to go dry. I then use the bulb to recharge the carburetor completely. Instead of a long dry cranking of the engine.
Reconnect connectors. 1 squeeze or 2 and engine is running with just a 1/4 of a second of starter cranking.
flyingscott
no it doesnt. That is not even close to true
flyingscott
Your bulb should not be hard after days. if it is the tank vent is suspect,
cyclops222
I always leave the tank filler cap loose. To prevent any possible high vacuum or overpressure of the pump or rubber tipped float pin.
Tassie 1
Dosen't answer your question but l bought a new primer and line a few months ago.
Wouldn't prime straight out of the packaging,
Luckily l had bought it locally...only a couple of mins drive.
Mechanic tested it on his system and it was faulty.
Replaced it.
Said it had probably been sitting on his shelf for 3 years.
