What causes the BEARING HOUSING SEAL assembly to fit loose
boobie
Re: What causes the BEARING HOUSING SEAL assembly to fit loose
Sorry, but I don't answer double posts!
KVH
Did you ever get an answer? I'm fixing mine right now! Defective manufacturer assembly is the main reason I'd suspect.
muskie00
One guy suggested to use a round shim?? I took a center punch and punched all around the loose area. This is working for now but it not a permanent solutions for sure.
