Re: What colour should my engine be- 40RL71G
Didn't look the number up but is it a 1971 Johnson 40HP? The hood was white,the leg was green, prop white,Seeing Evinrude and Johnson parts are interchangeable,I'd guess you have a cannibalized outboard part of both,But if the eng.# came off the plug on the motor that should be the motor,I believe there is no difference between evin. & John.except colors.Tiller handle was green also on johnson, bluish green evin.
I also will add the color of the powerhead was the color of the whole motor with the exception of the white hood and prop.
