what do i soak my carbs in?
Ranger01
I took my carbs apart and got the rebuild kit, but i want to soak them first and make sure i get them as clean as i can. When ever i use carb cleaner on aluminum parts there is always a white powdery build up left over and i dont want that in my carbs. I have seen those parts cleaner buckets you know with the basket so you can submerge the parts, is this a good idea? what should i use?
Walker
Re: what do i soak my carbs in?
I use Chemtool. Comes in a gallon can with a strainer basket. Never had it damage ant carbs.
Ranger01
that sounds just like what i was thinking, i want to make sure that they are clean. Any more tips on cleaning?
JB
A lot of "just cleaned" carbs don't work, Ranger.<br /><br />The most common mistake I have found is the three (usually) tiny passages into the carb throat near the throttle plate. They must be cleared. The soaking liquid often carries some varnish residue into them. High pressure air usually clears them, or you can gain access by removing the Welch plugs that are on the top of the carb body. There should be replacement plugs in your kit.<br /><br />Good luck. :)
Ranger01
i will definatly keep that in mind and pay close attention to that paert when i'm cleaning. i got the carb cleaner gallon and am soaking the lower half now, i will use compressed air and carb cleaner can to clear everything out, i have done car carbs before and always had then come out so i hope the boats is the same.
Walker
I rinse my barbs with aerosol carl cleaner when I take the out of the dip. Use the straw and blow cleaner through every orifice not matter how small, then blow with compressed air.<br />I also sometimes use a torch tip cleaner or fine wire like the wire that is in bread bag ties to get small passages if they are really clogged.
Ranger01
thanks walker, that's a good idea. i dont know how clogged the passages are but i know the engine like so many other sat for a long time and judging by the condition the guy left it in it probably had gas in it also. thanks for the help.
REELSPORT
Once you get them clean to keep them clean you might want to mix a little seafoam in you gas tank that will keep the carbs clean and disburse any condinsation that might form in them. You can find it at the local napa auto parts.
Ranger01
that's a great idea reelsport, i will definatly do that. how do you mix it in? i mean does it tell you how much to add for the gas you have?
tr918
Yes, there are directions on the back of the seafoam can.
