What do you guys think?
dkorzun21
Any one use Soft Scrub with Bleach too clean there hull.
Heard this works awesome but havent tried it and not sure if it will hurt anything. What you guys think.
airdvr1227
Re: What do you guys think?
Sounds reasonable. It does a great job on my porcelaine sink. I just wonder if it's too abrasive for gelcoat.
dkorzun21
Yeah thats what I was wondering do you think it will hurt my boat.
WAVENBYE2
Make sure its not abrasive, there are plenty of marine products out there for all your marine needs.:)
5150abf
NOOOOOO!!!
That is the equivalent of super heavy duty rubbing compound, it will scratch the pee out of your boat, way to abrasive.
It might get it clean but with all those fine scratches in it is will get twice a s dirty twice as fast and be harder to clean.
Porcelain is alot harder than gel coat, I would start with a finish rubbing compound and move up from there.
dkorzun21
ok so toilet bowl cleaner wil be better
WAVENBYE2
Yaa!! why not use 100grt. sand paper that will get off what ever is ailing ya!!
dingbat
Go down to Walmart and pick up a quart of Atwwod hull cleaner for $7. Dilute it 4:1 with water and put it in a garden sparyer. Spray down the hull. May take all of 5 minutes . Rinse liberal with water when done. Apply a coat of good wax and you're done.
By chance you run up and down the Hudson up by Waterford? Saw a boat looked just like yours past by several times last week while visting.
