basstracker1970
- Joined
- Feb 4, 2009
- 147
Ok I recently purchased a 1993 bass tracker tx-17 and it came with the tracker 40 johnson on it. The motor ran great when i purchased it. I even started it several times at home on muffs and it ran great. I took it out to the lake about a week ago for the first trip. It started up fine idled good like always took off down the lake ran awesome but didnt go very far because of the fog so i figured i would fish for a bit till it burned off. I started it up about an hour later started good put it in gear and blasted right out of the water. It ran wot about 30 seconds then started surging on me so i backed off on the throttle and it seemed to smooth out but you couldnt open it up. Shut it back down to idle and idle was rough now was smooth before this started so i figured carbs. I rebuilt the carbs twice to specs same thing wont idle now and its very rough and running rich. Doesnt seem like anything you do to the carbs fixes anything. I got to checking around on the wiring connectors one day and found something bad. The plug coming down from stator that has a,b,c,d,e was rubbing against the rectifier and the brown wire was almost rubbed in half and it looks like the wire was arking against the rec body and the other brown/yellow b wire was also rubbing and had a bare spot in it also. So im thinking
my problems that started are from this and not carbs since nothing you do to the carbs changes anything. It does sound like the motor is kinda cutting out at idle maybe one cylinder not sure. Done a spark test nice big blue sparks from each wire. I just keep thinking that that wire rubbing and grounding out like that had to kill the stator or power pack or both. What do you think ?????? I really need some ideas here guys I just want to go fishing in my new boat.......
