What do you think?
Bryan76
Took my boat to a mech for not running wot popping out the carb his conclusion is that timing is correct,carb working fine.He replaced gimble and told me that i have a 1.50 ratio which is for a V8 i have a 4.3 he said to reprop it and it should stop the popping i find it hard to believe it has a 19 pitch on it now......
Bryan76
Re: What do you think?
I knew it was bad and already had one but he came to the conclusion before the gimble bearing...I figured to go ahead and let him replace since i didnt have a slide hammer
90stingray
I dont think the popping is the drive ratio. I have a 1990 4.3 with the correct drive and she pops at wot. Been troublshooting that one since i bought her :( FYI- you can rent slide hammers at autozone or whatever parts house you have locally.
Bryan76
Whats your wot rpms mine are about 3800 then the popping begins and running about 33 to 34 mph via GPS
90stingray
Yeah, i have a 18p 4 blade prop and my popping starts at 3900. Put my 17p 5 blade and got her to 4400 before the backfire started. Prolly in the mid 30's on the mph.
Don S
1. What's a "Gimbal" I know what a gimbal Bearing is, a gimbal ring, and a gimbal housing. But nothing is named a "Gimble".
Anyway, if you have a 4.3, you should have a 1.84 gear ratio, not a 1.50. With a 19P prop, you don't have the proper WOT rpm, but that alone will not cause popping. You most likely have a lean condition, could be from air getting into the fuel system, a bad fuel pump, water in the carb, who knows at this point.
As an example, here is a list of things that cause low WOT rpm, but not all cause popping out the carb. That's fuel delivery problem.
http://forums.iboats.com/showthread.php?t=295070
Bryan76
Sorry about the INCORRECT word glad your on top of things but i will check into the fuel problem......
KCKracker
your mechanic is a thief. find a new one, period! popping is not normal nor caused by a gimbal.
HT32BSX115
I am going to have to assume that you meant gimbal BEARING
