crazytegger
- Joined
- Aug 30, 2007
- 3
I was looking over my motor today and I found a wire that was corroded or burnt through on one of the coils. It was the brown wire on the post directly above the post that the spark plug wire is connected to. The connector and post looked like they had a poor connection and had been corroded by arcing. Any insight would be great. I was ultimately trying to figure out why my overheat alarm was sounding. I can run the motor as long as I want with no alarm, but if I shut it off it will sound the overheat alarm next time I turn the key on. My guess is either I have a faulty sensor somewhere, or when the motor is not running, the water that is trapped in the cooling chamber heats up to "overheat" temp and then sets the alarm off. The alarm will go off about a minute or two after the motor starts running again. Any advice please?
