Re: What does "transistor igniter" do:re:Gamefisher 1.75
There is fuel in the carb bowl. This motor had a lot of "gum" in it from old fuel. I had to scrape out the gunk from the valve and fuel lines. Can you think of anything that would keep the fuel from getting to the chamber? .I don't believe this is the case...when I pull the plug it seems to smell of fuel. Also, how critical is the fuel ratio? I don't have it EXACT at 50:1, I did not need to make up a full gallon so I made a Liter of it and estimated oil to add.
