Surgeevg22
- Joined
- Jul 10, 2012
- 28
Hi guys,
I know I read the answer to this before but I have been searching for the answer and I can't find it.
Is there a specific cylinders pulse that drives the vro pump, and if it a specific one then which cylinder is it on a Johnson 115 cross flow engine. The pulse hose is on tHe starboard side, but there is a plug on the motor for the pulse limiter on the port side in between the carbs and starter. The plungeed up port is not in use given that it is a vro and not a fuel only pump.
I ask because I found the plug while diagnosing a fuel issue I have. That plug was loose and possible leaking. So I ask if the vro uses a specific cylinder for its pulse, or is it shared between all 4 cylinders.
Also if you have a conventional pump does it use the same cylinders pulse as the vro or does it rely on a didferent cylinder.
Thanks in advance.
Thanks in advance.
