Evil Eagle
- Joined
- Mar 26, 2012
- 23
Hey guys. I just want to first say how grateful I am to all of you for your advice, and help. Now, I am curious about what else I need to do before I put it on the lift at the lake for the summer. Here's what I have done. Replaced all seals in the outdrive, put in a new short yoke, water pump, and pressure tested it over night at 14psi. Then I replaced all 3 bellows, rubber water hose, trim switches, hinge pins, gimble bearing, and lower shift cable. Can you think of anything else? I'm a new boater so I'm learning as I go..
edit: forgot to mention that I heeded Dons warning and got the alignment tool. Thank goodness I did because it was out of alignment.
