What engine is this??
Ayuh,.... I donno where the guy is gettin' "327" from,....
It "appears" to be a 350, 5.7l motor, 'bout the same vintage as yer's,....
why not take your running 5.7 liter to a machine shop to freshen up vs buying another used motor?
if you have to redo the bores and touch the crank, it would be aprox the same cost to build a 383 stroker at that point which is what your cruiser needs.
mmetzger1028
Im new to the whole engine swapping, boring thing, so I don't even know what a 383 stroker is.......... lol
the 383 is a 0.030 over +.25" stroke motor. Mercruiser's 6.2 is a 377 stroker which simply does not have the over-bore.
basically for a boat, its big-block power out of the small block.
the crank is about $300, so if you need to machine your current crank, for any reason, a stroker build is cheep upgrade.
