I've done quite a bit of reading on the ethanol problem and I'm still confused.
Just bought a used 2001 Yamaha 100 HP Carborated Four Stroke. The engine runs great idle's great. (does however take a couple minutes to warm up)
From what I've read carborted four's have a greater tendency to get a clogged carb because of water build up. The water build up is caused by gas with ethanol in it. I asked the local Yamaha dealer what gas they would use in this engine and they told me to use whatever gas the previous owner had been using...however they suggested to run the Mercury ethanol additive with the gas. The prevous owner had been using low octane gas with ethanol.
So here are my question, what gas is best for this engine?
Low octane gas with ethanol and the Mercury Additive? Or
Premium gas with no ethanol and no Additive? Or
Premium gas with no ethanol + the additve?
Will running high octane gas hurt the engine at all?
If it wasn't for price would everyone just use the gas with no ethanol?
Thanks for the tips!
