What goes in!! Must come out!! Then what??
Hey all you water jockeys- Got a question for ya. Have not heard anybody
talkin bout this one lately. With winterizing coming and gear lube flying around and such. Well hear we go: When you drain your crank case oil from your motor you can take it to the auto parts store to dump it into a big
tank or drum. All's good no problem! But what do you do with gear lube?
Send it to the same grave as the motor oil??? And will the use of fogging oil cause your plugs to foul? Or can they be cleaned and reused next season?
Would it make sense to keep an older set-o-plugs for the fogging process?
The Sea Hag :):):D
3 litre merc / alpha 1 drive
Haut Medoc
Re: What goes in!! Must come out!! Then what??
Seattle has a household hazardous waste station....
I just put it in an old plastic milk carton......
The Sea Hag :):):D
Fogging oil won't foul your plugs....;)
Ayuh,....... Just dump it all into the same jug........
Nope,.... Not really.......
But,......
I do my Annual Tune-Up in the Spring.......
So the Sparkplugs are Fresh each Spring........
Thanks for the quick responses! Popeye would be proud of ya! I figured that since just about everybody dumps different grades and weights of motor oil into those disgard drums and tanks at the auto parts stores that you could just make a "lube cocktail" and dump her in ! Stirred not shaken of coarse!
and hold the olives please . leave that to Popeye..... :eek::D:)
Sea Hag - out!:):)
