what happens if timing is off
zenchal26
Lets say the timing of the cams to crank shaft is 180 out on a 115hp merc four stroke outboard. What damage will happen?
MARB415
Re: what happens if timing is off
If it is a interference engine you can get bent valves and piston damage
ONERCBOATER
did it make bad noises? or lock up?
zenchal26
no noises or lock up but the marina said there were bent valves hard to believe with no noises or lockup.
