What Holley Carb Do I have?
whitesig
Glass Master 1976, OMC V8 175 HP with a 302 Ford<br /><br />The Motocraft Number on the carb is D3JL 9510-S.<br /><br />It is a Holley 2 BBL. I've given up on rebuilding the carb and want to buy either a used or new one. I can't find a holley part number on the carb. I've looked on the web for replacements and there seem to be several and differ by the CFM. I can't find a reference to the CFM in the boat manual I have.
outboardguy
Re: What Holley Carb Do I have?
I believe the identification number that is needed to find out what carb it is should be on the air horn. It should say LIST (4560)for example.As far as CFM goes take a look at holley's website and they tell you how to find the proper CFM carb for your engine.<br /><br /> http://holley.com/HiOctn/ProdLine/Products/FMS/FMSC/FMSC.html <br /><br />Good Luck :)
mkast
As long as your replacing the carb, look into replacing the manifold so you can install a four barrel carb. Your 302 will fly.
JasonB
The Holley I see on *most* 302's is a 300cfm. If you are having to buy a new carb, I would seriously look at a 4bbl upgrade. Edelbrock makes a 600cfm that can be had for under $300, Holles makes a 450cfm, which tends to be pricey, and holely also makes a 500cfm 2bbl, but I don't know how that would work on an otherwise stock motor. Intakes are't that expensive.
