Lou C
- Joined
- Nov 10, 2002
- 13,023
OK I had just rebuilt my Q-Jet and still had the 30 year old Carter mechanical pump on it. Well I replaced that petrified old yellow tygon hose for the fuel pump overflow, and in a few days, I saw what looked like gas in the new hose! So of course I replaced the pump with the Sierra one I bought a few years earlier in anticipation that this old pump would give up sooner or later. A few days later I got curious. And checked that fitting on the pump after taking it apart.......what I found was that it was totally plugged up with some sludge like black crumbly stuff. There was no sign at all of gas in the lower chamber and the diaphragm was still in good shape. Not sure where this sludge like stuff came from but it was a bit oily, smelled faintly like gas/oil. BUT, if there was really a gas leak, I can't see how you'd notice it unless you got way down low and really looked because the only trace of gas, was a tiny bit in the lowest part of the hose way down by the pump. So anyone who has one of these style pumps, might want to replace that tygon hose and keep and eye on it.
I cleaned out the crud in the passage and sure enough you can see if that diaphragm fails, there is a passage that will let the gas out into the hose, but not if its plugged up with whatever that crud was....
