Re: What is a "good" cylinder pressure?
Service manual for Merc mid range engines (P/N 90-830234R3, December 1997) Pg, 1C-6 "Compression Check" Para. 5: "Check and record compression of each cylinder. The highest and lowest reading recorded should not differ by more than 15% (see example chart below). A reading below 120 psi might indicate a total engine wear problem."
So what difference does it make? Dunno. May matter to some people, may not to others. May matter to you if your engine is borderline. Meter calibration could very well swamp out any differences between psig and % and so could measurement technique, especially on engines (like the older 4/6 cyl Mercs) where it is hard to get to the top and bottom cylinders. So could worn seals on the instrument. Degree of carbon contamination on rings/grooves also could play a role. Makes for wide interpretation on the part of the owner and the mechanic.
But, I have always used "within 10 psig" until recently when I stumbled upon this. So there you have it.....My 2c and worth every penny you paid for it. Ha.
Mark
