Re: What is a Jack Plate
A jack plate is for raising or lowering an outboard motor. A jackplate would be installed by removing the motor, bolting the jackplate to the transom in the motor's former place and then bolting the motor to the jackplate.<br /><br />Some jackplates are manual operation, requiring a few bolts on the sides to be loosened, the hieght adjusted by a center vertical bolt or two, and the side bolts retightened.<br /><br />Others are electric or hydraulic operated allowing hieght adjusment on the fly. These would require wiring and sometimes hydraulic plumbing to be installed.<br /><br />The simplest type offers no adjustment and is not really a jackplate but a setback device.
