What is a self bailing boat?
BugsBunnyBoater
I feel a bit slow but when I loook this question up I never get a really good answer.
LOL So its time for this teacher to be the student ( yes I teach school )
What does it mean when it says a boat is self bailing?
Thanks for the Answers in advance.:)
zinc
Re: What is a self bailing boat?
Water that has accumulated in the cockpit area drains out back into the river
thru which is called "SCUPPERS"
These are located higher above the water line and are just basically a tube
which passes thru the stern, sometimes the side of the boat and may have a rubber flapper on them to prevent sea water from re entering,
Hence the term "self bailing"
sv fisherman
Im pretty clueless- 1st post. but I thought of it like the big boats on the deadliest catch. Big waves wash over the bow and the water goes out through the holes on the sides.
jdlough
Sv....
Yeah, that's what everyone here would LIKE our boats to do, but those TV guy's decks are about 20' above the waterline and are designed to quickly dump tons of water. For most of us, we get a hole which drains thru little hoses to the outside - sometimes above and sometimes BELOW the waterline.... (the hose can sometimes (but rarely) crack, let in seawater, and sink the boat) If you do have a deck scupper which drains out to a below sea level thru-hull fitting, make sure you know how to shut off the sea-**** (if your boat has one) usually right at the hull. Sometimes there are other dangerous below-waterline openings - like for wash-down systems or live-wells. The sea-**** should ALWAYS be shut for them when not in use.
I asked for a clarification of self-bailing near the end of this post:
http://forums.iboats.com/showthread.php?t=272550
I got this reply re self bailing decks vs self bailing boats/hulls:
"a self bailing deck is not the same as a self bailing hull. On a self bailing deck, the deck is above the waterline and there are scuppers that will direct the water overboard rather than into the bilge. Water can still get into the bilge though (especially through the anchor and ski lockers), and this water needs to be pumped out.
Self bailing hulls are pretty much unsinkable, they don't have a bilge and will float even with the plug out (most will fill a little at rest but will empty out when on plane)."
To which I replied:
"I did not know that. I was thinking that if a self bailing deck boat was left at dock in the rain with a dead battery, it could not sink. If I understand it, it just wouldn't sink as quickly, but would eventually sink when enough water seeped into the bilge via any storage compartment or other hatch leaks.
I was wondering why a boat with a self bailing deck would need a bilge pump.
This explains it."
