what is best way to fill in stripped wood hole?
aggiedave98
My engine cover that pivots on two hinges has one hinge where all 3 screws are pulling out of the wood. What should I use to fill the holes, then screw the screws back in? Would regular wood filler hold?
Wotknot
Re: what is best way to fill in stripped wood hole?
drill out the stripped holes to a certain diameter....1/4" i.e. Then get a dowel rod that same size, cut off 3 pieces the lenth you need to fill the holes you just drilled. Glue in the 3 pieces, let the glue dry, then redrill the hinge holes into the newly filled holes. Probably be best to use waterproof glue, too.
blackz3
oak dowels r ur best bet
jlinder
Good old trick. I've used it around the house for door hinges, lock screws, etc.<br /><br />Just make sure that the hole you drill matches the dowel. When you put the dowel in you should need to tap it in with a hammer. The tight fit, along with the fultes on the dowel and whatever you screw in (it forces the dowel to expand a little) will give you a repair that will not pull out, even before the glue dries.
trog100
the easiest way assuming u have a reasonable screw length and the wood u are fixing to isnt rotten is to just tap some thing slivers of wood down into the hole cut them off flush with the top and simply screw the screw back in..<br /><br />trog100
djvan
My engine cover has small bolts with nuts on the backside. If yours is accessable this might be a good remedy.<br /><br />DougV>
Boomyal
Originally posted by djvan:<br /> My engine cover has small bolts with nuts on the backside. If yours is accessable this might be a good remedy.<br /><br />DougV>
Undoubtedly the best way djvan, if'n you have access, that is.
marinemech1
wooden match sticks work real well also
trog100
marinemech1.. yes matchsticks were the standard thing.. wooden cocktail sticks might be easier to find now thow.. he he.. nobody seems to use matches anymore..<br /><br />my workshelf always has tub of wooden cocktail sticks on it.. remarkably usefull things for purposes other than their intended one.. he he<br /><br />trog100
marinemech1
cocktail?/ too high brow for me lol
Reel Poor
you can fill the holes with a two part epoxy. Drill and rescrew. Wont rot or get soft.
Liquid_force
Originally posted by Reelpoor:<br /> you can fill the holes with a two part epoxy. Drill and rescrew. Wont rot or get soft.
X2<br />Marine tex is excellent for that type of repair. Not cheap, but it is super handy. I've used it to repair stripped screw holes in wood, and to fill a couple deep, ugly gouges in my boat's hull (previous owner). Worked perfectly in both applications.
MGallik
I've used tooth picks dipped in Elmers Glue. Stick em in and snap em off.
