What is gas tank made out of?
paulgp6022
Hi, In my 2000 Fisher Avenger sport 16 aluminum, what is the onboard gas tank made out of? Thanks for any info.
paulgp6022
Re: What is gas tank made out of?
Thanks for the link! If it is aluminum, I don't have to worry about rust right?
roscoe
Correct.<br /><br />It could also be fiberglass.
paulgp6022
So either is better than regular metal correct?
Capn Mike
Most "modern" (i.e., since 1970) boats (except for some inboards) use aluminum, plastic or fiberglass. If you have an aluminum boat, 99% of the time the tank will be made out of the same materials.<br />Plastic composites have gained popularity even in aluminum boats, since there's no concern about welds, corrosion or electrolosis. If I were building a new boat today, that's what I would specify.
