oldrudedude
- Joined
- Jul 3, 2008
- 480
I have two props:
- One is -----------> 12 3/4 X 23
- the other is -----> 13 3/4 X 15
- The 23 is a much more agressive pitch but the diameter is smaller.
How do I calculate top speed difference and/or hole shot performance?
The 13 3/4 X 15 is presently on my 16.5 deep V bowrider with early 70's 100hp Johnson.
The 12 3/4 X 23 is from a blown 140hp Johnson.
Both are aluminium three blade props.
Gearbox appears 2:1 ratio.
I saw an online calculator but it doesn't mention prop diameter. Why not?
OK, I know someone is going to ask: What is present RPM at WOT? Well, I don't know. That is why I installed the tach today. Haven't had a chance to try it yet. The engine was originally on an early 70's 17.5 Crestliner Muskie (my friend called it Marg the Barge). Perhaps that is why the motor has such a low pitch prop. The motor has good hole shot on the present boat but I am getting low to mid thirties for top speed. I am wundering if the 12.75 X 23 is too much prop for that old motor.
If I swap my two props what differences would I expect to see?
