What is Seafoam
Dusky Mike
I have some gunk and water in my fuel tanks. Will this help? Where can I get it, at West Marine or someplace similar?
jtexas
Re: What is Seafoam
No additive will help with the gunk and water in the tanks. They have to be drained and cleaned. Once you've got fresh gas in a clean tank, seafoam will help keep it fresh and prevent carbon buildup in your engine.
I've found it at Autozone, O'Reilly's and Auto Quest.
Wellwater
Re: What is Seafoam
Seafoam is the miracle solvent that will work for just about anything that runs on gasoline. cleans and protects.
bruceb58
Re: What is Seafoam
SeaFoam is part Naptha...part Isopropyl Alcohol...and part pale oil.
No miracles!
OptsyEagle
Re: What is Seafoam
What ratio of seafoam to gas do you guys put in when you just want to maintain your motor and stabilize the fuel?
jtexas
Re: What is Seafoam
I run about an ounce per gallon of premix - think that's a little less than recommended on the can.
Dusky Mike
Re: What is Seafoam
Can says 1 oz per gallon. BTW...this stuff is awesome...it looked like the engine was on fire, but seemed to help my problem somewhat.
