Re: what is special about a merc 60hp bigfoot?
I checked the LU oil, its clear with no filings, I can check the compression, but there is currently no way to start it. (He does not have the cables, nor tank.) and the motor fuel fitting is differnt then mine.
He bought it new in '98, but the motor SN indicates '99 ( so it was an early '99) The motor looks visually fine (LU has no dings, cowling has scratches but that is is.) No prop.
I wonder if the prop on my 115 would work ( you say its the same LU as a 90 ( which I read somewhere is the old 115).
Debating on talking him down, IF compression is OK. and install it on my toon myself ( rent a hoist). Marina want 360 to install it! My cables will plug in, so dont see why it would cost so much to install.
