What is the actual lenght of 14' steering cable?
victor26086
Ok this might be a silly question but I need to know if the actual size of a 14' cable is 14' from tip to tip (far side of rack to far side of the tilt tube).
If this is not the way they determine what length a cable is called then whats the method?
THANKS
victor26086
roscoe
Re: What is the actual lenght of 14' steering cable?
It also says this, if you don't have an old cable to measure:
New Installation:
Measure cable routing path from wheel center line to engine connection, as follows:
A= Center line of wheel to gunwale (or deck, if routed downward),
B= Dash to transom,
C = Gunwale to centerline of cable connection at centered tiller.
For Cable Installations through the Engine Tilt Tube: Add A, B & C + 6?, then round up to the next foot. Order that length cable.
For Cables Mounted to Transom, Splashwell or Stringer: Add A, B & C, then subtract 6? and round up to the next foot. Order that length cable.
