?Impeller should be replaced as well I prefer the 6 vane impeller over the 10 Part?.
What is the advantage or disadvantage of a 6 vs 10 vane impeller? I?m waiting for a 10 vane Sierra that I just ordered. The existing 10 vain was last checked in 1985 (used about 2-3 hrs per summer in fresh water) and had what I considered a good output/stream. The old impeller is flexible w/o dangerous surface cracks but the vanes are not straight ?at rest positions?. I?m anxious to see if the new impeller will give a more solid stream vs airrated.
I?m also noticing that my Clymer?s manual shows that the vanes flex more with the higher RPM. I wonder if the stream is reduced or compensated from the RPM and design of the 10 vane Sierra impeller?
Thanks in advance for any info.
JOW
JOW
