tashasdaddy said:the first thing you do, is stop at the dealer and pick up new seals for the plugs, #1 cause for lower damage. and buy one of these. the lube must go in the bottom to fill all the areas. Thank you
http://www.iboats.com/Fluid_Pump_Lu...55660691--list_time.1174999162--view_id.56375
fill the unit until the oil comes your the top hole, insert top plug, then disconnect and insert bottom plug. with the electric shift us to correct lube, to avoid problems.
