mcdonkey37
- Joined
- Jun 12, 2009
- 19
I had an overheating problem with the top 2 cylinders. I want to make sure that water is circulating through the block and getting to the top cylinders. The motor is a 1973 evinrude 135 hp.
To my knowledge so far, there is no pee-hole by the exhaust and the water exits down by the prop. If it is hooked to muffs, then the garden hose is pushing the water through, and in the river you cant see it exit by the prop.
So, what is the best way to check that the water flow and pump is working properly?
thanks
thanks
