What is the correct starting procedure
cobra1476
Hi Guys! I have a 2002 Optimax 150XL saltwater series (carb) on my rig and I always have a hard time starting it the first time. It always starts but just the initial first of the day start is a pain to do.
It may just be me but it takes me about 3-4 cranks to get it fired up. It feels like it takes forever because I am always rushing at the ramp.
So here is what I do when I start is.
-Lower the motor so it is sitting as close to parallel to the water.
-squeeze the primer bulb until it gets hard.
-turn ignition to on and push to choke for 3 to 4sec.
-pump my throttle forward twice and leave it a bit forward.
-turn key a couple times until it fires.
Again, it starts all the time but it just takes 3 to 4 turns. Once I have it running, the rest of the day is good. Just turn the key and starts. Weird or normal?
efdog
Re: What is the correct starting procedure
Have you tried anything different?
I have a carb merc, and do not hold the choke in that long prior to starting, unless it's been out of the water for a very long time. Aside from that, it sounds like everything you do is the same as what I'm doing.
Do you have choke push on the ignition? Try to choke it only while you are turning the engine over. That's what I do, if it's taking a couple seconds to run, then a couple short bursts of fuel with the throttle.
cobra1476
Oh are you suppose to push the choke on while turning over? lol! It does make sense. I just push it for a couple of seconds let go then turn.
aussieflash
Cobra,what your doing is correct,hold in for few seconds then turn key.Throttle needs to be open when cranking,then lowered quick when she starts.
cobra1476
Ok. now I'm confused? Hold, let go, then turn?
jigmister
You can hold it in while cranking if needed. The key primes the engine just like you were to pour some fuel down the carb throats with a gas can. I do the same as you are. After it fires up I tap the key to feed a little more as needed to keep her from dieing.
If I hold it in too long it will die as that is flooding it.
You are doing the right things. Its just a carbed engine. Remeber the old cars? had to warm em up with the gas pedal in the mornings.
444
Put the throttle full forward when cranking and pull it back fast once she fires. Mine has the choke flapper doors so I have to hold it while cranking. My previous merc had the choke (electric primer) so before cranking I would push in the key 3 or 4 times to give it a few shots of fuel before hitting the key and did not hold the choke/primer while cranking.
Cricket Too
How do you have an Optimax that is carbed??
cobra1476
I think the saltwater series under 200 aren't efi's.
Cricket Too
No Opti's are EFI's, EFI's are a whole different animal.
Optimax is the name of the DI system, why would anything be an Optimax that didn't have the Optimax injection system??
No such thing as a carbed Ficht or Etec or else they wouldn't be an Etec.
emoney
I always thought that Optimax's were injected too?
Cricket Too
They are....Direct Injected. Not EFI or carbed.
Starting procedure should be, put the key in and turn it, that's it.
Dave1027
That's exactly what I thought. Not like the old days. Now the computer does all the futzing for you.
