what is the correct way to remove shift lever
glassport
Need to remove shift lever so I can get panel off. Merc 470, shifter has HI-LEX on the plastic cap. On the handle there is a tilt trim toggle, but there also seems to be a tilt toggle on the panel along side the handle. Can I just cut the wires and splice later to remove? Thanks for your[IMGjpg?t]://http:/http/i668.photobucket.com/albums/vv49/rusticreflections42/IMG_0689-1.=1242896506[/IMG] help
oops!
Re: what is the correct way to remove shift lever
hi.....welcome to i boats.....
im not sure you are in the right forum.....so im going to ask the mods there opinion....they might move this to an area ..(like electronics or the i/o forum where the guys there are more framilliar with each particular shifter.
cheers
oops
