Re: What is the difference tru-hub prop and non-thurhub prop
Years ago Merc realized that if you put the exhaust in the center of the propeller "propwash" the wash will carry it well behind the boat and it will run quiter....yeah, a quiet tower of power.......Ha, Ha. They also realized, as did others, that rather than a conical cap on the end of the propshaft to reduce drag, you can pump the void behind the propshaft full of exhaust gasses and reduce/eliminate it.
In comes the thru hub exhaust.....mid '60's as I recall. and out goes the popular (everybody did it that way back then) exhaust tube at the rear of the antivent plate....................till Brunswick purchases Chrysler...ala Force.
Next thing you see is the Force still exhausts out the back of the antivent plate, but they have (what looks to be) a standard Merc "thru hub" prop on it. Well, what happens to drag when you have this empty, squared off, tube at the center of the propwash. Well, it mustn't be good for performance or over the years, all the designers that made streamlined gearboxes were just nuts! I seriously doubt that.
I never saw data on the Force lower unit before and after they went with the actual thru hub exhaust. A comparison would be interesting.
I had the Chrysler 85, before the Brunswick takeover, and it had a very long, definite cone on the tail end of the prop shaft.....nice and aerodynamic.
More of my 2c's.
Mark
